Old 04-03-2006, 04:34 PM   #1
pmg1704
'93 Taurus Wagon starts....sometimes
Hi, first time poster so please forgive if the etiquette isn't quite there yet.
My 93 Taurus wagon is in great shape, 150K miles but well maintained.
Recently a new problem appeared. The car will not turn over randomly when I try to start it. This happens every once in a while. When I put the key in and turn, the electrics come on, I can put the car in neutral, start the radio, the dashboard lights come on, but the car won't turn over. It won't even try. Then I wait a few minutes, fiddle with transmission (into and out of neutral), try again and sometimes it works sometimes I have to wait longer and try again. Eventually it works and the car starts right up.
The battery is pretty new, less than 1 year old. I was thinking the starter, but then it wouldn't start ever(?) Whenever this happens I noticed that the brake is very hard, I can't press it down.
Any thoughts or suggestions? I'd rather not have to pay the IRS and my mechanic in the same month....thanks.
pmg1704 is offline   Reply With Quote
Old 04-03-2006, 07:05 PM   #2
I could go really far out and say distributor, but that doesnt explain the brakes being so stiff......
actually i cant think of anything that would cause these problems...
Old 04-03-2006, 07:09 PM   #3
davsmitty
davsmitty's Avatar
Im thinking a sensor somewhere. Maybe the "parked" sensor, most newer cars wont allow you to start the car in any gear. Since it sometimes turns over after you mess with the shifter, it might not be getting a good signal in "P" *shrugg* not a clue about the brakes though.
davsmitty is offline   Reply With Quote
Old 04-03-2006, 07:14 PM   #4
Do we have to go over this again?
Old 06-15-2006, 10:43 AM   #5
john316
93 Taurus
Sounds like a transmission range switch to me. (some shops call it the "prndl" switch) When it won't crank, try holding the key to the start position while moving the shift lever through the range. If it tries to start, it is a safe bet that it needs this switch. Be prepared should the engine try to start while in gear. The switch is around $50 and is easy to replace.
john316 is offline   Reply With Quote
