Old 04-06-2006, 04:27 AM   #1
Aondor
Aondor's Avatar
stronger 250 6
Ok call me retarded but right now im running a 250 that only produces 98 horses when new and now has 55k miles and a lot years.
can i rebuild my current engine to be as strong as the 150 hp early version of the motor. If i can't what if I found an in shape 69 250 6 and dropped it in my car Im sure there are a host of performance options.
Is a souped up 250 just a waste of my time?
I think it was just be cool to have a fast (musclish car) with a straight 6.
I figure I could easily get 200 horses from a n/a 250.(with work time and effort)
Or should i just do the unoriginal thing and go v8.
Aondor is offline   Reply With Quote
Old 04-06-2006, 05:22 PM   #2
Scolson
Scolson's Avatar
Do the unoriginal thing.
-Chuck Norris is not hung like a horse / horses are hung like Chuck Norris.
-Chuck Norris lost his virginity before his dad did.
-Chuck Norris can make a woman climax by simply pointing at her and saying "booya".
-Chuck Norris only masturbates to pictures of Chuck Norris.
-Chuck Norris invented water.
Scolson is offline   Reply With Quote
Old 04-07-2006, 02:51 AM   #3
philo
Assuming you are looking at the GM 250/6, take a look at the Pontiac version, from 66-69. It was the base 230 engine with an add-on OHC and 10.5/1 compression (1969), and 230 HP. I think it was a two valve head, but did have a four barrel carb on the higher performance versions. It would be a good starting point for you.
philo is offline   Reply With Quote
Old 04-07-2006, 02:59 AM   #4
dodger65
I know more than Wally...
dodger65's Avatar
based on his avatar, i'm gonna say we're dealing w/ a ford 250...
...and i think the pmd motor was different than the chevy (i just don't care enough to look it up right now...)
you could, with the right parts and info, build a pretty mean 250. it might also be worth looking into whether the 250 shares a bellhousing bolt pattern w/ the 300 inline 6...
Old 04-07-2006, 03:33 AM   #5
philo
Hey, it's late. Can't see everything (and didn't look either!)...
It was the same block, but of course it had a cam belt system and a few other changes.
Old 04-07-2006, 03:51 AM   #6
The Pontiac OHC engine had the same block as the Chevy 250? Are you sure about that? If they're the same block, why doesn't the Pontiac have any provision for an in block camshaft, has an external oil pump instead of an internal one and has a different bellhousing bolt pattern? Teach us.
Old 04-07-2006, 03:59 AM   #7
dodger65
dodger65's Avatar
thanks for doing my homework, hobo.... you can have the snack pack out of my lunch tomorrow...
Old 04-07-2006, 09:18 PM   #8
philo
Thanks for the 'trip'. After some research, found (as you already know) that bore spacing and displacement are about the only like specs. That's what I get for listening to others (back then) rather than looking for myself. There was probably no damage done, since I was the only one with the wrong information, and I don't have one of the engines. And it gave you guys something to zing me on.
Old 04-07-2006, 09:20 PM   #9
if you want to be really original with power still,
do a twin turbo
although i doubt theres any kits around...
Old 04-07-2006, 11:16 PM   #10
Good god man, you'll never last on this forum. You were found to have made a mistake, followed up on it with research and corrected yourself. What will all the worthless little Twinks (you know who you are) on this forum think of you?
Welcome to the forum, philo. I think you'll make a wonderful addition. We need more adults here.
Old 04-07-2006, 11:28 PM   #11
dodger65
dodger65's Avatar
i'll second that: true wisdom is knowing that you know nothing...
Old 04-08-2006, 12:43 AM   #12
Aondor
Aondor's Avatar
How would i find out out about the bolt housing of the 300 inline?
Ok so my qestion is pretyt much this am i better to start out with my current engine or an older Ford 250 6?
any sites for some some detail information on these engines.
Aparently I found alot about there being performance straigt 6 in heavy use in australia in the ford falcons there maybe i could try to locate that engine.
Im going to go do some asking around places see what i find out form some people.
Old 04-08-2006, 02:02 AM   #13
philo
Thanks, I plan on sticking around, and continuing to do more reading than posting. And I'll be remembering that a closed mouth gathers no feet.
