Old 04-30-2006, 11:36 PM   #1
amyb123
96 Olds Ciera blowing fuses
Wondering if anyone can shed some light on my predicament. I put in a different radio in a 96 Olds Ciera. After a minute or so the CTSY 20 amp fuse blows. I have a wiring harness attaching the new radio, aren't there some unneeded wires I can disconnect so resolve this?
amyb123 is offline   Reply With Quote
Old 04-30-2006, 11:45 PM   #2
Does the fuse still blow if you disconnect the "harness"? Doing some investigative work BEFORE asking for help will help everyone find the answer quicker.
Old 05-01-2006, 12:38 AM   #3
amyb123
NO. When the factory radio is in the fuses are fine.
Old 05-01-2006, 12:43 AM   #4
That did not address or answer the question.
Old 05-01-2006, 02:13 AM   #5
amyb123
Sorry, I misunderstood. The fuse is fine and does not blow if I disconnect the harness. I had the same problem happen when I installed a radio in a 98 Saturn but unconnecting some of the unnecessary wires between the new radio and harness did the trick. Unfortunately I do not know which wires I can disable without losing the ability to use the radio.
Old 05-01-2006, 04:19 AM   #6
And what does it do if you have the "harness" connected but the head unit disconnected?
Old 05-01-2006, 09:02 PM   #7
amyb123
I am not that good....what is the head unit?
Old 05-01-2006, 10:23 PM   #8
http://members.optusnet.com.au/benje..._600pxWide.jpg
