Old 05-12-2006, 01:16 PM   #1
soapmom1
1991 Honda Civic DX Starting Problems
I am have intermittant starting problems with my 1991 Honda Civic DX.
The following has been replaced.
A new Distributor cap/rotor button
A new battery
A new alternator
A new fuel filter
A new air filter
There is spark. The batter and alternator were tested and are charged well.
There is fuel pressure most of the time. Occassional the fuel pressure is at zero when trying to start and other times there is fuel pressure and the car still won't start.
A rebuilt engine was put in December 2005. The car runs beautifully when it is started.
soapmom1 is offline   Reply With Quote
Old 05-15-2006, 03:15 AM   #2
soapmom1
Codes
Don't know what you mean by codes.
Old 07-28-2006, 11:03 AM   #3
n25gabe
I had an intermittent starting prob on my esi, when you try starting does the rev counter shoot up? If so the prob might be with your starter moter, since i cleaned it up, ive never had a prob starting
n25gabe is offline   Reply With Quote
Old 07-31-2006, 03:48 AM   #4
EvilPodAE
Its probably the starter.. It could also be the fuel pump, its acting very scidish. What is the fuel pressure?
EvilPodAE is offline   Reply With Quote
Old 01-05-2009, 01:53 AM   #5
Burakcan
1991 Honda Civic DX starting problem
Hello,
I have 1991 Honda Civic DX 1.5 Hatchback car. It's been giving me headache for two weeks. It starts normally then after driving around 20 km (less or more) it stops itself. I leave it couple hours then when I try to start again it starts. It happened 6 times so far. A mechanic said fuel pump relay (Main relay) problem. I took 2 relay from junk yard and replaced it but the problem is continue. Does any one have an idea about this problem? Which part can cause this problem?
TX.
Burakcan is offline   Reply With Quote
