Old 04-04-2004, 04:03 AM   #16
Originally Posted by Novaleigh
Hes actually 35. And this is not the first time that he has done something like this. And I am doing the work because I am the responsible one.
Would the engine even try to turn over, or would there be just nothing. Also, if it were the starter engine that shorted, which has been suggested to me, wouldnt push starting it work? (He tried that, and it didnt)
-Nova
That's why you have to diagnose in a logical order. If it's not the starter and it's hydro locked you'll do more damage by trying to push start it. That's why I told you the first thing to do is check to see if the engine turns over by hand. I was working on the assumption your car was an automatic. I had to assume because you didn't tell us. That doesn't matter, don't push start until you know for sure the engine isn't locked.
Old 04-04-2004, 05:13 AM   #17
I bet people in Moosejaw can hear the argument that's taking place right now.
Old 04-04-2004, 05:29 AM   #18
Novaleigh
ok, well, I found some info on how to remove spark plugs, and it seems pretty simple, I think that I can do that. How exactly do you turn the engine over manually?
By the way, I really apreciate this, I know that I am frusterating the hell out of you.
So....try to turn it over manually, if it doesnt work, remove spark plugs and try again, turn starter with plugs removed to push water out of cylinders. Put spark plugs back in and pray????
-Nova
Novaleigh is offline   Reply With Quote
Old 04-04-2004, 05:34 AM   #19
-Nova
Find the crankshaft pulley. The bolt that holds it on has a 22mm (7/8" will work) head if memory serves. The easiest (only) way to turn it over is with a large ratchet or breaker bar and socket. You'll probably need the right front corner of the car jacked up to do this and also remove the splash shield.
Bingo on everything else.
Old 04-04-2004, 05:46 AM   #20
Novaleigh
ok, thank you. I apreciate your help and I hope that it works. Otherwise, off to the mechanics. I think that hubby can sleep in the f**king car for a few nights.
Old 04-04-2004, 11:31 PM   #21
tbaxleyjr
Sounds like hubby is going to need an operation - the kind where he has to go to a hospital and have someone's boot surgically removed from his hind parts.
tbaxleyjr is offline   Reply With Quote
Old 04-05-2004, 06:13 PM   #22
karburator
CF Spain HQ
karburator's Avatar
Definitely, people has very strange habits
http://www.car-forums.com/talk/showthread.php?t=2280
At least present case doesn't look so serious as the one I linked.
Ciao!!
>Supported by Happy Modem
It cannot be so difficult. The instruction manual will tell me which pedal is the 'velocitator' and which one is the... 'deceleratrix' (by Mr. C.M. Burns)
May God bless those who have nothing to say and, furthermore, they keep quiet (by someone)
karburator is offline   Reply With Quote
Old 04-05-2004, 10:18 PM   #23
Novaleigh
Arrrghhhh!
Alright, I did all that. I took the spark plugs out, only when I took the boots off, the plugs were about 8 inches down these little holes. So when I turned the engine over with the ratchet, about an eighth of an inch of water is sitting there now. So what I did was put a peice of paper towel over the holes so crap doesnt fall down in there and am letting it evaporate. I cant think of any other way to soak it up. I also took the filter out, and it is SOAKED. So that is drying too.
Will the spark plugs need to be replaced? How can you tell when they are shot? They were damp when I took them out.
I am getting really frusterated. Thanks for your help.
-Nova
Old 04-05-2004, 10:54 PM   #24
-Nova
So far, so good. If the engine is turning over by hand go ahead and crank it over with the starter. No need to go nuts, just two or three 5 second cranks will do the trick.
As for the sparkplugs, for what they cost go ahead and replace them. While you're at it replace the air filter too. Total cost maybe $15. Put it all back together, yell contact and crank it up. The first start will probably be pretty tough. Keep your ears tuned in for any unusual and expensive noises. Once it starts if everything sounds okay, let it warm up and you should be good to go.
Old 04-05-2004, 11:30 PM   #25
Novaleigh
yeah, when I tried that, with the starter, it still made the same sound. The clicking sound. Its the initial sound that the car makes when you start it (if everything were healthy) but then there is nothing.
Old 04-05-2004, 11:39 PM   #26
So it has trouble turning over? this may sound silly but, is the battery charged?
Old 04-06-2004, 12:03 AM   #27
Novaleigh
I hooked up a charger to it and it said that it was good. Plus all the interior lights come on and the stereo still plays.
Old 04-06-2004, 12:10 AM   #28
tbaxleyjr
Since we can crank the engine by hand, its time to chase down the electrical gremlins.
Begin with what Cliffy said first - check and see if the battery has a full charge. Little other trouble shooting of electrical issues can be done without the battery being charged. Once the battery is charged, there are a couple of checks you can make to determine if the solenoid needs to be replaced of if the starter is bad. In the US, a starter solenoid for a 1994 Altima is about $40, a starter is about $130 plus installation if someone else does the work
Old 04-06-2004, 12:54 AM   #29
Novaleigh
This may sound like a stupid question, but I am pretty sure that I turned the bolt attatched to the crankshaft pulley, but how can I identify it for sure?
Old 04-06-2004, 02:24 AM   #30
tbaxleyjr
If my daughter had my 1999 Altima here, I would take a digital picture and show you. Since is still away where she attends school, I'll try to describe it the best I can.
Looking on the passenger side into the engine compartment, the crankshaft pulley is the large one immediately to the left of the air conditioning compressor. The crankshaft pulley will be driving two belts (the ac compressor and the alternator/water pump) The bolt on this pulley is the one vwhobo asked you to turn with the plugs out to ensure you have no water inside the engine
You may have to access this from behind the passenger front tire if you cant reach it from the top. This side of the Altys gets kind of crowded
