Old 06-07-2006, 03:21 AM   #1
Toxsiniq
Question basics?
I just got my first car approx. 1 hour ago. It a Pontiac Perisenne(sp)? Bourgham 4 door 8 cylinder. Its power EVERYTHING! But yes, umm...I have no idea about basic maintenance...So could someone tell me like a checklist of things.wow..those are sum angry smilies!---> Okay, no more distractions. So yes I will check this later..or email me at bluemoolover@yahoo.com
Toxsiniq is offline   Reply With Quote
Old 06-07-2006, 04:46 AM   #2
FORDRANGERBOY
FORDRANGERBOY's Avatar
first off when you buy a new car you should all ways change the oil, or at least pay somone to change it if you don know how. all so id check the tire tread and air pressure. but befor i buy a used car i go get it checked out by an auto mecanic first b4 i buy it. you might wanna go do that to make shure that theres nothing seriously wrong with it, if there is id just turn around and sell it.
-dan
FORDRANGERBOY is offline   Reply With Quote
Old 06-07-2006, 04:49 AM   #3
-dan
Umm..or maybe if there is something wrong with it he could make it interesting and try to fix it?
Old 06-07-2006, 04:57 AM   #4
FORDRANGERBOY
^^yes i agree^^^100%
but if he doesnt know how to upkeep a vehicle then that might be kinda hard,
-dan
Old 06-07-2006, 08:20 AM   #5
automan
automan's Avatar
ok here are the basics
Congrats and good luck with your new car.
here is a list for your reference:
change the engine oil
check the transmission fluid
anti freeze level
change the air filter
change the sparkplugs or have a new tune up ( which would include air filter and spark plugs)
check the brake fluids
check on the tire pressure
make sure your spare tire is in good shape and properly inflated
check to see your jack is available as well.
change the fuel filter if the previous owner never did.
Ok these are not all necessary immediatly, but the the fluids and oils yes, you should take care of asap.
Maintaining your car will save you lots of money and save you on fuel costs. A clean air filter will increase your mileage per gallon by up to 5% believe it or not
Good luck.
automan
good post, no ads
automan is offline   Reply With Quote
Old 06-08-2006, 07:46 PM   #6
Toxsiniq
-dan
Just to let you know i am a SHE!
Old 06-08-2006, 07:51 PM   #7
Prove it
Old 06-08-2006, 07:53 PM   #8
Toxsiniq
anti freeze level
Good luck.
automan
good post, no ads
I of course had it checked by a mechanic(my moms friend)
i have so far added oil, i have to get it changed later with a tune up
I have checked the other liquids
It has a brand new air filter
I have no idea where the spark plugs are
it has power brakes and they seem to work too well but i have no idea how to mess with them
i have good air pressure but i need to replace the tire soon b/c the tread is worn down
i have a spare tire, a jack, a tire iron, two screwdrivers, a hammer, a flashlight, a hubcap offer dilly, some jumper cables and a multi tool in my trunk(just in case) there is also a first aid kit in the glove box
where is the fuel filter?
Old 06-08-2006, 07:53 PM   #9
*sniffs* smell that boys?..... PICTURE TIME!
Old 06-08-2006, 07:54 PM   #10
FORDRANGERBOY
Prove it
^^^hahahahah
well im sorry about that and good for you being a girl and wanting to do the work yourself!!
-dan
Old 06-08-2006, 07:54 PM   #11
Toxsiniq
Prove that i am a she..im sixteen perv! and you are like what? Ami the only girl on this entire forum???
Old 06-08-2006, 07:56 PM   #12
Naw, I'm 15 and got a g/f (i'm just tryin to help Chris out with pics) , Chris here is the same age as me
Old 06-08-2006, 07:56 PM   #13
Toxsiniq
not so much
Old 06-08-2006, 07:57 PM   #14
Toxsiniq
There happy?
Old 06-08-2006, 08:00 PM   #15
Toxsiniq
Originally Posted by tbaxleyjr
inspect air filter, pvc inlet filter @ air cleaner, pcv valve (replace if nasty)
inspect exhaust system, fuel, brake, cooling system, power steering systems for leaks
inspect hoses and belts (replace as needed)
inspect steering linkages, tie rod ends, ball joints, etc.
rotate tires
inspect brake pads and shoes for wear, same basic inspections as @ 3000-
check choke operation
check antifreeze strength
test charging system
tune-up include
replace spark plugs, dist cap and rotor, pcv valve, air cleaner, fuel filter, pcv inlet @ air cleaner, and O2 sensor
Adjust (if required and if procedures are available in shop manual) curb idle, high idle, ignition timing
inspect/re-torque carb to intake mounting bolts, Emission control systems
check ignition system econdary voltage with a spark tester
flush cooling system and refill with fresh antifreeze-water mixture
Ok i left everthing that i don't know how to do in the quote
