Old 07-08-2006, 11:57 PM   #1
gntlmanpharmer
PT Cruiser Headlamps
It seems that the gasket on my 2001 PT Cruiser have broken down and now the lens are all fogged up. I went to my dealer and bought the gaskets, hoping that it would be easy to replace. For the life of me, I can not figure out how to take the lens off to replace the gasket.
Thanks for the help
gntlmanpharmer is offline   Reply With Quote
Old 07-09-2006, 03:56 AM   #2
O-P-ET
use some headlight fluid, or check to see if the problem is coming from your exhaust belt. happened to me before too
O-P-ET is offline   Reply With Quote
Old 07-09-2006, 03:59 AM   #3
Give him some help if he needs it, don't be stupid
Old 07-09-2006, 01:53 PM   #4
Oh, you mean like this, right?
It could be low headlight fluid, check that before anything
http://www.car-forums.com/talk/showt...eadlight+fluid
And let's not forget this helpful response either.
Dude you forgot the headlight fluid, that may do some damage too
Pot, kettle, black Steven. Get with the program or quit whining.
Old 07-09-2006, 01:58 PM   #5
I had a feeling someone was gonna come through with that but I was cranky that day and needed Midol
Old 07-09-2006, 08:48 PM   #6
gntlmanpharmer
Question
Thanks for the replies, but what does any of this have to do with my question?
Old 07-09-2006, 09:04 PM   #7
I'm soooo sorry, we all forgot. This forum is ALL ABOUT YOU. It's your world and we're just passing through.
What have you done for us lately, newb?
Old 07-10-2006, 06:25 PM   #8
O-P-ET
if we dont reply we dont know, well im talking about myself i dont know how that works for other people.mplus maybe you should like talk to a proffesional.
Old 07-10-2006, 06:26 PM   #9
Who is this post directed to and what is the point of it?
Old 07-10-2006, 07:11 PM   #10
Thanks for the help
There should be a 6" square access panel ahead of the front wheels in the weelwell. Remove that and you should have access to the headlight mountings.
The assembly, however, is a one piece unit, and I'm suprised you could get the "gasket" separate.
DC did have a TSB issued on this in August 2005, where they indicated some moisture is normal inside the headlamp unit and will appear as a cloudy or foggy condition inside the assembly. The moisture can be removed by activating the headlamps on high beam for 15 minutes. If water droplets larger than 1mm in size have accumulated on the inside of the headlamp lens, the headlamp assembly should be replaced.
Old 07-14-2006, 05:49 AM   #11
EdenGenesis
To get the lense apart from the housing you need to bake it, put it in the oven for about 10 minutes at around 200 degrees, this will loosen the clauking that's holding the lense to the houseing, put in the gasket reseal and you're done. I know the baking sounds crazy, but that's how you get it apart, hope it works out.
EdenGenesis is offline   Reply With Quote
