Old 07-23-2006, 02:06 AM   #1
Manual Window Crank Reinstallation
I know how to remove the window crank. If you don't have a special tool you have to use a towel or screwdriver to get the clip off. Correct? Anyways, how do you put the clip back on?
2001cavalier is offline   Reply With Quote
Old 07-25-2006, 05:06 PM   #2
Lizard King 6B
Lizard King 6B's Avatar
I usually put in position with my fingers, then push it into place with a flathead screwdriver. Sometimes they slip out of position but after a try or two you should be able to get it back on.
Grant me the serenity to accept the things I cannot change,
The courage to change the things I cannot accept,
And the wisdom to hide the bodies of those people I had to
kill today because they pissed me off.
Lizard King 6B is offline   Reply With Quote
Old 07-27-2006, 07:44 AM   #3
I usually just stick the clip on the handle and push it on. If it doesn't go on with the clip all the way on, then pull the clip out a little bit until it does go on and make sure it snaps in place, if not the push on it with something
