Old 11-14-2006, 01:45 AM   #1
supernova72
no start 91 cutlass
no start 91 cutlass car has 3.1 engine it has spark and fuel the problem is the injectors the when testing if the injectors are flashing the light is dim. i checked the power on one side it has 12 volts and th other is ground it checks good i replaced ecm problem still there also cleaned grounds for ecm. need help.
supernova72 is offline   Reply With Quote
Old 11-18-2006, 01:55 AM   #2
supernova72
thanks for all the help i fixed it one of the injectors was bad one was shorted out making allthe others not working.
