Old 11-14-2006, 04:11 AM   #1
Twinturboseph
Dual Battery
Hi guys can someone please help me, Im trying to install a spare battery in the trunk of a 00 Impala and i was wondering how i would go about connecting the alt to the spare battery
Thank you
Twinturboseph is offline   Reply With Quote
Old 11-14-2006, 04:22 AM   #2
Are you thinking about making the two batteries work together at the same time, or when one cuts out, the other to take its place?
Old 11-14-2006, 05:11 AM   #3
Twinturboseph
both at the same time
One to run the car the other for the system so yes both at the same time thank you
Old 11-14-2006, 01:30 PM   #4
davsmitty
davsmitty's Avatar
good, stereo->i can help with that at least. What you want to do is wire the batt's in parrallel, so run a large wire from your main battery posistive to your second batt positive terminal (use at least 4awg wire, recomend 0awg though) and you can wire the amp from the second batt pos. For the ground, just bolt a short wire of the same size as the power wire to the chassie and make sure the metal is bare and clean (no paint or rust). Your amp can share the same ground as the batt, it wont hurt anything.
This setup will double your useable amperage (which=more play time) but the voltage will remain the same. you might chech on this at a local audio shop to see that its done correctly. heres a link to an audio forum, its about the biggest and best around IMO
http://www.realmofexcursion.com/
davsmitty is offline   Reply With Quote
