Old 11-15-2006, 02:05 AM   #1
klaus
95 Buick LeSabre No Start When Wet
Hi,
I have a 95 Buick LeSabre which will not start when wet. If left overnight in the rain, it will not start in the morning. Also, on the fair weather days, it runs kinda crappy as well, missing on the highway etc. New plugs, wires, fuel pump. No check engine light on. Assume it is getting fuel because of the smell after cranking for a while. Hopefully someone can straighten me out...otherwise to the junkyard it goes!
Thanks,
Klaus
klaus is offline   Reply With Quote
Old 11-18-2006, 12:29 AM   #2
mastera1
[quote=klaus]Hi,
Thanks,
Klaus[/QUOTE
the problem with your car is the module/ coil pack assy i have been through many times before]
mastera1 is offline   Reply With Quote
Old 11-18-2006, 11:19 PM   #3
klaus
OK Thanks...
As you know there are 3 coil packs and a module which they sit on top of. Would you shotgun everything or is there an EASY to troublshoot? When running, the coilpacks appear to firing properly...or at least produce a spark, unknown as to whether it is strong enough.
Thanks,
Chris
Old 11-19-2006, 12:07 AM   #4
dodger65
I know more than Wally...
dodger65's Avatar
if you get a shop manual for it, it should show what the resistance should be when you check the coils....
