Old 01-18-2007, 06:13 AM   #1
jhaugh
93 mx6 starting problems
I am new so any help will be apperciated. My 93 mx6 will not start. It appears that the coil side of the fuel pump relay is not getting a ground to close the relay and run the pump. If I take the relay out and jump the contacts the car will start. I can then remove the jumper and put the relay in quickly and the car will continue to run although with a high idle(1200-1600). I am looking for the possible cause of this. I have the cars wiring diagrams(alldata.com) but cannot pinpoint the problem. I also have good continuity from the relay to the PCM. Any ideas.
jhaugh is offline   Reply With Quote
Old 02-22-2007, 11:31 PM   #2
Nickboxer7
Nickboxer7's Avatar
Did I misunderstand something, b/c it seems like what you told us is that the relay is bad.
Nickboxer7 is offline   Reply With Quote
