Old 01-28-2007, 05:32 PM   #1
Door Chime Disconnect
How the f*ck do you disconnect that annoying ass chime when you open your door with the keys in the ignition, anywhere I should look? I looked in my Haynes and nothins really in there about it. Any suggestions?
Old 01-28-2007, 05:46 PM   #2
thefonz
Remove your key lock cylinder, and remove the plastic piece that is on it. It just snaps off. Should be black or orange, with thin copper strips on it. Reinstall your cylinder and you're good to go.
( I guess you are talking about your ranger)
thefonz is offline   Reply With Quote
Old 01-28-2007, 07:17 PM   #3
yeah i am and i'll try to do that ASAP
Old 01-28-2007, 07:19 PM   #4
Does it continue even if the keys are out of the ignition? Usually the bells will only sound if the keys are in the ignition as a way of warning you that either you have left the keys in the ignition, or you have an open door. Either way, is it really that annoying for you? lol
Old 01-28-2007, 07:53 PM   #5
Have you checked your owners manual? I removed the chime from the truck here on the farm(thing spends a lot of time with the door open, so it gets annoying fast), it was just a little "module" under the dash. I found the information in the same section as the fuses in the manual.
Disclaimer: I know not all vehicles are the same, I'm just offering my suggestion.
Old 01-28-2007, 09:51 PM   #6
Cliffy: Thanks for movin this I thought it was more off topic, and yeah if I put the key in the ignition it will chime with my door open and yea its very annoying if you do a lot of movin shit and pickin up stuff for buisnesses because as Jeff said your door is open a lot.
Dodger: I'll check the owners manual right now I'll be back wit an update.
Old 01-29-2007, 01:09 AM   #7
It's ok. It was to do with fixing/dismantling something so I thought it would fit better in here!
