Old 02-15-2007, 07:05 AM   #1
nate wesselink
nate wesselink's Avatar
Help
i have a big problem i bought a 94 eclipse gs in december and i guess i didnt check my oil levels because i ended up spinning my main and rod bearings the parts are only 65 bucks but labors gana be 400 or so so is there a way i could do it myself without screwin my engine i have the chiltons manual for my car but it doesnt say how to replace the bearings or where they are any info and any sites i could find a diagram on that part of my engine
it has a 1.8 liter 5 speed mulitport fuel injection i got it up to 110@5500 rpm so ya its pretty fast for a stock 1.8 is it possable for me to do it myself without screwin my engine over any info is greatly appreciated
without car mods i would have no reason to live
nate wesselink is offline   Reply With Quote
Old 02-15-2007, 07:53 AM   #2
Wally
I Know More Than You
Wally's Avatar
Fairly straight forward job for the experienced, however you will need to get some tools, gaskets, micrometers, etc. I would suggest you find a mate who has a father who has the tools and nous.
Old 02-15-2007, 08:03 AM   #3
nate wesselink
i have all the tools i need for it i just need a diagram and instructions to do it
Old 02-15-2007, 02:31 PM   #4
[sarcasm]I'll assume this belongs in the R&M section.....I just found it hard to read....[/sarcasm]
Old 02-15-2007, 02:49 PM   #5
glagon1979
daddy x3
glagon1979's Avatar
i officially have a headache.
this forum is to dead to share a cool sig with everybody....
glagon1979 is offline   Reply With Quote
Old 02-15-2007, 11:54 PM   #6
Wally
Wally's Avatar
I would do a little investigative work before going out and buying bearings. Drain the oil and drop the sump. Take a bigend cap that and inspect the surfaces for gauling. If it looks Ok get some plastigage and cramp the cap assembly back on to see what oil clearance you actually have. Similarly drop the centremain bearing (ideally the one with the thrust plate or washers) and test with plastigage ...... crank bearings tend to wear very slowly compared to the bigend bearings, so chances are they should be satisfactory. Make sure you measure the thrust dimensions (a dial guage on the end of the crank is the best way, but may be hard to apply with an insitu engine).
If tolerances aren't within spec you will need to measure the crankpins for wear, out of round and taper. If the pins aren't within tolerance you will be faced with a dilemna = do you take the crank out and have it reground or do you do a Heath Robinson by replacing the bearings and hoping for the best.
Once you have the bearings in and lubricated (which they should be before you put them in), take the spark plugs out, remove any drive belts associated with the crank and make sure you can spin the engine by hand.
OH and make sure you mark each bearing cap prior to removing so you can reinstall to it's mating journal and orientation.
Old 02-16-2007, 03:40 AM   #7
windsonian
Dodger65's weirdo
windsonian's Avatar
Keeping up salty fluids should prevent cramping
Old 02-16-2007, 04:17 AM   #8
Wally
Wally's Avatar
Which is probably why you shouldn't pour salty water into crankcases.
Old 02-16-2007, 05:14 AM   #9
nate wesselink
thanks wally hopefully itll work for me i really hate haveing to drive a van instead of my car
