Old 02-17-2007, 08:28 PM   #1
mrshooff
Question Bleeding a slave cly 95 maxima
A guys I had to replace a line to my slave cly and can't get it to prime this is a crazy design. Any help i sure could use. Thanks
mrshooff is offline   Reply With Quote
Old 02-21-2007, 05:49 PM   #2
This is not a crazy design, this is a standard clutch hydraulic system. Have you followed the bleed procedure in your service manual? You are using a service manual, aren't you?
Old 03-02-2007, 01:46 AM   #3
mrshooff
Yes I always use the manual. It's telling me about the bleeder on the cyl. when there's another one mounted on the fire wall coming off a large coil of a metal line. Whats the reason for that? A CRAZY DESIGN!!!!
Old 03-05-2007, 01:15 AM   #4
carls47807
CF Freak
it's not crazy, just bleed it as described by the manual. you probably have to bleed the master before you do the slave if there are 2 fittings.
