Old 02-17-2007, 08:57 PM   #1
Miniman
2000 Neon nightmare
My 2000 Neon has weird things going on like a dinging sound, doors locking non stop, blinkers acting up and door and fuse messages above odometer while driving. I changed the dash cluster but still same issues. I read here somewhere that someone had similar problems. At my whits end. Any advice would be great.
Thanks
Miniman
Miniman is offline   Reply With Quote
Old 02-22-2007, 11:27 PM   #2
Nickboxer7
Nickboxer7's Avatar
Not too sure. It seems like all the intermittent stuff is getting power non-stop, so it sounds like a wiring problem or a bad relay maybe. You might want to see if in a Chilton or Haynes manual any of those things is a code. For example, my car will flash the check engine light so many times if something is wrong I think. But if everything is going off, it's more than likely not a code. A mechanic or auto electrical shop should be able to find out.
Nickboxer7 is offline   Reply With Quote
