Old 02-22-2007, 04:46 AM   #1
azme737
95 chevy p/u 4x4 tranny slip/lock-up
Transmission acts like it is slipping, but also locked between gears. The gauges don't work and the "Check Gauges" light keeps flashing. The gauges and light problem started at the same time the trans problems started. Any ideas as what is wrong?
azme737 is offline   Reply With Quote
Old 03-05-2007, 01:10 AM   #2
carls47807
CF Freak
Try getting the codes read, and get back to us.
Old 03-11-2007, 11:41 PM   #3
azme737
95 chevy p/u 4x4 tranny problems
the codes are
66 ECM Resett or 3-2 shift control solenoid
67 Torque converter solenoid
81 Trans solenoid "B" 3-2 shift
82 Trans solenoid "A" 1-2 shift
83 Torque converter clutch solenoid
after resetting the computer, the tach worked then went dead and the codes are
66 ECM reset or 3-2 shift control solenoid
If I drive it, the other codes will probably get stored again also.
Old 03-13-2007, 04:53 AM   #4
talon699
talon699's Avatar
Is this a 700r4? Sounds like an electrical problem
talon699 is offline   Reply With Quote
