Old 02-23-2007, 12:19 AM   #1
paulrcummings
LeSabre front wheel brg install help
Hi folks, I am new to this forum and I own a 96 Buick Lesabre. I am told that it needs a front wheel bearing. Can I do this myself? The dealer wants over 500.00 to do the job. Is it a straight forward install or are there special tools procedures to do this?
Can you help with letting me know the procedure or is there a writeup somewhere?
Thanks
paul
paulrcummings is offline   Reply With Quote
Old 02-23-2007, 12:37 AM   #2
TexTruck
TexTruck's Avatar
Thanks
A bearing job is pretty easy. Pick up a haynes manual on your car for a guide. You also will want a bearing puller. You might not need it but it'll be nice to have if you do need it. Also keep in mind that you may have to dis connect a tie-rod or similar part to get at the bolts holding your bearing on. I did. But you may not too. Also as a beginner you'll wanna know that you need to remove your brake calipers and your rotors to remove your bearings. I'm a novice myself and will likely get reminded by others who may respond but there's enough info there to get you going!
TexTruck is offline   Reply With Quote
Old 02-23-2007, 12:45 AM   #3
Thanks
paul
1. Yes you can do this yourself... If you have the appropriate service manual, some basic tools and average mechanical ability.
2. Yes it is a straightforward job. I can do them in about 20 minutes, it would probably take you about three hours if the above requirements are met.
3. 500 bones is an exorbitant amount for this job. Leave the dealer and go to an independent repair shop that employs ASE certified technicians. You'll get better service and pay about half.
Old 02-23-2007, 03:02 AM   #4
BanffAutoSpa_ap
Pants The Ripper
BanffAutoSpa_ap's Avatar
i can do them in 19 that includes 2 gulps of coffee, and washing my hands. just ribbin ya hobo
