Old 03-12-2007, 12:22 PM   #1
Mondeo 'Fuel door release'
The Fuel door release lever isn't working. It feels loose and unconnected. Any idea where the cable for this is located or how to get to it? Is it a big job to fix it? Thanks.
paw2007 is offline   Reply With Quote
Old 03-12-2007, 09:28 PM   #2
Pants The Ripper
BanffAutoSpa_ap's Avatar
well just a stab in the dark because i have never even seen a mondeo before. a cable is a cable is a cable, so step 1 check the end that would physically connect to the release handle, is it still attached? probably, now open the trunk and look behind carpeting or plastic trim or a an access panel located directly behind the gas tank fill door, or very near, you should be able to locate 1 or 2 things, the cable that will attach to the fill door, is that end disconnected? probably but if not then the cable has broken in between or very stretched out in which case you need a new cable, regardless there shoulb be an emergency open latch somewhere in the trunk, and you can still open it to fill up, good luck
Old 03-13-2007, 12:34 AM   #3
Our Mondeo is what you guys would call a 'Contour' I believe....Other than that, the fundamentals are the same in most circumstances as far as his problem goes, I guess. Nothing further to add.
