Old 03-19-2007, 12:19 PM   #1
share2go
pontiac sunbird se 1994-2.0 wont start
i have a pontiac sunbird se 1994 ,i get switch and starter but the engine wont start . i put a special spray in the engine to see if there is a spark but its still wont start.change the batery .
i have light etc.. ,
before this problem the car was working and cuting out after 1 hour
i had to wait 30 mn and restart it again and it was working again for another hour or so.
another problem was a noise that the car was doing when working.
i have change batery , disarmed and disconected the alarm , change all oil ,gaz and water in the car . change oil filter,air filter,gas filter ,engine oils a special cleaning solution for the gaz injectors thanks and pump . 4 new sparks and new cooling water for the engine, but still wont start . i have starter and hear the stater working ok
what could be the problem please ?i just want to burn the car it will cost me less money.never buy a pontiac sunbird in your life a lemon junky car.
every mechanic that check the car tell me something else
1. timing belt
2.oxigen sensors
3.gaz pump
4.cleaning the injectors.
PLEASE .................................................. .H.E.L.P
Signature Removed
share2go is offline   Reply With Quote
Old 03-30-2007, 02:58 AM   #2
carls47807
CF Freak
ignition coil
