Old 04-21-2007, 01:03 PM   #1
whicky1978
Could I clean Hyundai Headlamps by taking them apart?
I drive a 2001 Hyundai Elantra, and the headlamps are cloudy from the inside, is there a way to take them appart and clean them? I've tried, but I don't think I could do it without a hack saw, and then they would go back together the same way.
I'm thinking I'll need to spend $200 for new ones. Are there any special bulbs that don't cause cloudiness?
whicky1978 is offline   Reply With Quote
Old 04-22-2007, 12:10 AM   #2
The reason they're 'cloudy' is probably due to condensation. You could clean them inside if you can find a way how, but it'll probably just happen again. You could always find out why they're steming up (usually water leaking in through a crack or seal), then see if you can find a way to clean them inside and replace/repair where the water is leaking in at.....Or you could always find a new headlight unit. You could probably find one at a scrapyard or something alot cheaper than new.
Old 04-22-2007, 03:07 AM   #3
whicky1978
I know that one headlamp does get wet inside, but that's because I broke the seal trying to take it apart. It seems impossible, but I thought I would ask.
I wouldn't mind a used set, if they are clear.
