Old 06-29-2007, 02:38 AM   #1
jacobjoey
stuck valve
on a 55 crown vic, 272, fordomatic, we have a stuck valve on # 3 cyl. Car was in a barn for years, we have spark & fuel, also had 1/2 cup of wheat seeds in # 1 cyl, darn mice! Car cranks, won't start, found stuck valve yesterday, any ideas how to unstick? I've soaked with wd-40, spring doesn't budge, thanks in advance.
jacobjoey is offline   Reply With Quote
Old 07-02-2007, 06:24 AM   #2
try taking off the rocker arm or at least loosening it, then removing the valve and spring, move the rocker arm up, and reinstall...or take it to a shop and have them do it..if you dont reinstall it all correctly its gona throw ur timing off and car might misfire
Old 07-05-2007, 10:57 PM   #3
dodger65
I know more than Wally...
dodger65's Avatar
you've got to be shitting me.... once again, STFU!
Old 07-05-2007, 11:00 PM   #4
dodger65
dodger65's Avatar
really your best bet is going to be removing the heads and checking it out. after sitting for years, it could be any number of reasons that it is stuck. i'd have to say #1 potential reason would be rust on the stem. if the car hasn't been run for a long time and that valve has been in that open position, all kinds of moisture and very small critters could have gotten in there.
edit: you say there was 1/2 cup of seeds in #1 cylinder... does that mean you have the head off already and can't get the valve out?
