Old 07-17-2007, 02:19 AM   #1
cdixon311
wheel/column locks in the 'on' position
I recently swapped my power steering rack and tilt column for a manual rack and a junkyard column without tilt. It all works fine, but now is the wheel doesn't lock when it's supposed to. When the key is off it spins freely. When you turn the car to on it will occasionally lock. I pulled it all apart again today and now it will only lock once when you first turn the car on but not right away. It usually waits till I pull out. I'm at a loss at the moment about how to disable it or to make it correct. Any ideas?
cdixon311 is offline   Reply With Quote
Old 07-19-2007, 02:45 AM   #2
cdixon311
problem solved. I just drilled out the lock.
