Old 07-20-2007, 12:00 PM   #1
94 Lincoln Towncar Door Lock Problem
All of a sudden the passenger side door lock does not work. The actual switch you press to lock/unlock doors works but the lock on the door does not go back and forth, in fact you can't even move it manually, along with the fact you cannot turn the key to force the door to lock as well. Any ideas as to what will cause this
Towncar94 is offline   Reply With Quote
Old 07-21-2007, 02:47 AM   #2
Some Fords have a solenoid and some have a motor to work the lock. Most likely it has siezed.
thefonz is offline   Reply With Quote
