Old 07-31-2007, 01:14 AM   #1
DrCarnage
How many jump starts?
How many times should you jump start a car?
DrCarnage is offline   Reply With Quote
Old 07-31-2007, 01:53 PM   #2
adamc44
CF Freak
adamc44's Avatar
til it starts
AMERICA: LOVE IT OR LEAVE IT
Old 07-31-2007, 05:59 PM   #3
DrCarnage
I guess i mean, until its not healthy for the car/battery or is that not a problem?
Old 07-31-2007, 10:47 PM   #4
If you need to jump start it that many times, you should probably consider some simple diagnostic work!
Old 08-08-2007, 10:37 PM   #5
scrapper
jump start
take it and have alt. checked and battery..they'll do this free at autozone or advanced..good luck..
scrapper
scrapper is offline   Reply With Quote
Old 01-04-2008, 05:27 AM   #6
2Loud
2Loud's Avatar
Pull a battery terminal
If you pull a battery terminal while the car is running and it dies, The alternator is bad, if it continues to run, replace the battery.
2Loud is offline   Reply With Quote
Old 01-04-2008, 05:35 AM   #7
tbaxleyjr
The above statement is smart - very smart. (notice a hint of sarcasm here)
One can take a volt meter and determine if there are between 13.5 and 14.5 V @ the battery with engine on (an initial screen test to determine if the alternator needs to be tested) If outside these ranges or if the voltage goes outside these ranges if the lights are turned on too, the odds of a bad alternator are very high or possibly the voltage regulator - either way additional trouble shooting / diagnostics are in order I haven't verified if a 95 Taurus has an internal regulator or an external one or not thus a shop manual would be of great help when doing this kind of trouble shooting.
The only way to diagnose a bad battery is to do a load test.
tbaxleyjr is offline   Reply With Quote
