Old 08-09-2007, 05:46 PM   #1
Cranking issue??
Having a strange problem and this is the first time its happened. Went out to the car this morning, and it cranked (turned over) but didnt start. took out the key and tried again, no dice. tried the 3rd time and it started fine. Went to my mechanic and he said that if it happens again then its a problem, he said it could have just been a freak incident
car is a 2001 honda civic lx 5-speed non vtec 113.5k miles
Any ideas of things I should start checking??
I tried to pump the gas as it was cranking but it didnt help
Old 08-09-2007, 06:31 PM   #2
ateymura
would do plenty good to your liver if you listened to you mechanic and didn't freak out just yet. if it happens again I would check the battery.. how old is it?
ateymura is offline   Reply With Quote
Old 08-09-2007, 06:46 PM   #3
No idea how old it is, but me and my grandpop checked the voltage and electrolyte density and everything came out good. (by electrolyte i mean we took the cover off and took the fluid from the each of the 6 cells into a special tube with little balls inside and everything was good.)
Im not at the freaking point quite yet, but I just want to start checking some things as soon as possible, so if there is a problem that it doesnt pop up when im miles from home and need a tow truck
Old 08-10-2007, 11:51 AM   #4
thefonz
If it is cranking fine in a no start condition, I would think the battery would be the last thing to check.
thefonz is offline   Reply With Quote
Old 08-11-2007, 03:05 AM   #5
Turns out it was a bad terminal ring for the power wire going to the battery. all is fine now
Old 08-12-2007, 03:54 PM   #6
ateymura
as you see you would think wrong
Old 08-12-2007, 04:11 PM   #7
thefonz
It was a wire, not the battery. Who's wrong now?
Old 08-12-2007, 10:59 PM   #8
ateymura
wire that connects your battery to the rest of your car...
Old 08-13-2007, 12:01 AM   #9
thefonz
You are just proving your ignorance, quite well. It is not the battery, it is the wire. Why must you make it so hard? Too much for you to comprehend.
Old 08-13-2007, 12:42 AM   #10
windsonian
Dodger65's weirdo
windsonian's Avatar
Wow, this is a smart group
Old 08-13-2007, 01:39 AM   #11
thefonz
Yep, proven on here on a daily basis. See, I can be sarcastic too.
Old 08-13-2007, 06:34 AM   #12
Fonz, I havent seen you answer anything, just point out things you think are wrong with what other people are saying..you are the new hobo of CF
Old 08-13-2007, 11:54 AM   #13
thefonz
Nope, just trying to politely tell people either their guess was wrong and why it didn't make sense.That can be a way of helping, so maybe in the future, it would help them. In the other case, that the answer was given. The guy was trying to be a smart ass. Besides, you are going by the last couple of posts I made. I try to help when I feel I can. (which isn't very often )
There is only one Hobo!
Old 08-13-2007, 09:30 PM   #14
ateymura
So you call me ignorant where apparently you have no clue of what you are talking about.
how would you tell the difference between bad battery, good contact(wire) and good battery, bad contact(wire) ????????????.. in both cases there is not enough current getting to the car... either it will crank but not produce good enough spark.. or it wont crank at all. And yes checking the battery does mean to check the voltage on it, clean the battery terminals off corosion and inspect the wires.
well at least hobo knows what he is talking about...
Old 08-13-2007, 10:39 PM   #15
67Coronet383
CF Riff Master
67Coronet383's Avatar
lol these dumbasses on CF will never change...
