Old 10-08-2007, 11:27 PM   #1
hkyfan2
Tire Width
I am building a custom frame for my 67 chevelle. I want to increase the frt tire width (wide track) which would make the frt 2" (centre - centre) than the rear. I am wondering if this is acceptable. I dont want to widen the rear diff & order custom axles. I think the rear must be wider than the frt ( no real reason just always thought it was). I would appreciate some info & input.
hkyfan2 is offline   Reply With Quote
Old 10-09-2007, 12:12 AM   #2
windsonian
Dodger65's weirdo
windsonian's Avatar
so you're using the same tyres, but just increasing the track width?
Old 10-09-2007, 02:21 AM   #3
hkyfan2
No Im installing 18" tires with a stock offset. And yes i want to increase track width ( 1" per side )
Old 10-09-2007, 03:01 AM   #4
windsonian
Dodger65's weirdo
windsonian's Avatar
18"?!?! wow.... mine are 205's... yours are going to be 457's .... and on the front too...
Old 10-09-2007, 03:18 AM   #5
hkyfan2
Funny guy, anyone else that know anything that actually helps.
Old 10-09-2007, 03:40 AM   #6
windsonian
Dodger65's weirdo
windsonian's Avatar
I'm being serious.... you're putting 18" wide tyres on the front?
What's the reasoning behind the extra inch track width?
Old 10-09-2007, 06:03 AM   #7
hkyfan2
Ok its a slow night up here in Canada, so I'll bite. No the tires are not 18" wide they are 18" rims (in diameter) the tires are 245's. So that would read 245/45X18. I hope that clears up this confusion. Most people know when someone say's they are running 18's they mean rim diameter.
Old 10-09-2007, 06:35 AM   #8
windsonian
Dodger65's weirdo
windsonian's Avatar
so my question still stands ... the tyre width is the same or different?
what i'm getting at is that a track width increase of 2" may mean the outside-outside width of your tyres is increased by a bit more than 2"
Old 10-17-2007, 11:29 PM   #9
rudypoochris
If you want to increase track 1" per side just subtract 25.4 from your offset. Provided these are the same width wheels. Done.
rudypoochris is offline   Reply With Quote
