Old 01-17-2008, 02:49 AM   #1
ryano
Need help with 4Runner
I have a '91 Toyota 4Runner, that revs up and down while idling. Also, while I'm driving, if I try to hold a constant pressure on the gas pedal.. the truck will "jump" or "buck". But when I am speeding up, (or not giving it gas at all) it will drive smoothly. Every once in a while the 'check engine' light will come on. The gas is just being eaten up, and I can smell fuel when I'm staying still.. I think from the exhaust. Anyone have any ideas on what is going on? I thought maybe the TPS was causing the jumping and revving, but when i unplugged it, there was no change. Also, I was curious if a bad O2 sensor could be causing the fuel to be used so quickly and have to do with the smell of fuel. I haven't tried replacing that yet, I just wanted to get any ideas before I went to pick up some new parts. Thanks in advance!
ryano is offline   Reply With Quote
Old 02-10-2008, 11:04 PM   #2
DARKtEAGLE
DARKtEAGLE's Avatar
my father had the same problem wit a bronco 2 so i checked and replaced all the esentials like( coil, spark plugs,spark plug wires,distributer and cap, fuel regulater, and cloged air filter lol) but the same problem still occured. so pondered about online looking for info an i found this site. i sat back dumbfounded for a min. they said replace the 02 sensor. so i did and the bronco runs great. plus i even gain some of his MPG's back. so yeah 02 sensor work for me. so it would prolly work for u. so good luck
DARKtEAGLE is offline   Reply With Quote
Old 02-11-2008, 12:25 AM   #3
tbaxleyjr
replacing the O2 sensor will work if the O2 sensor is bad.
Since the check engine light is on, have you found out what codes are being thrown before buying parts? - Normally when it comes on or flashes on and off when driving, there is a reason it is on.
tbaxleyjr is offline   Reply With Quote
