Old 06-03-2008, 05:57 AM   #1
tp101
2002 focus trunk
i got a 02 ford focus. the trunk latch will not open useing the dash button or key fob. the key however works just fine. any ideas on how to fix? already tried a new latch still didn't work.
tp101 is offline   Reply With Quote
Old 06-03-2008, 06:47 PM   #2
thefonz
If it works fine with the key, then yep, you wasted your money on a latch. Can you hear it 'click' or try to release when you use the fob or button? If not, have you checked fuses? If you can hear it click make sure it is connected to the latch. You should have had to remove the electric part to change out the latch.
thefonz is offline   Reply With Quote
Old 06-04-2008, 05:12 AM   #3
tp101
i checked all all of that. it dose make a clicking sound. everything is pluged back in. i didn't know if their was a servo or someting that would cause this to not work properly.
Old 06-04-2008, 07:36 PM   #4
thefonz
The electric release has to be attached to the latch you said you replaced. Is it attached or just hanging loose in the trunk?
Old 06-09-2008, 08:00 PM   #5
tp101
attatced. i made sure that it was put back together properly
