Old 10-07-2008, 09:45 PM   #1
DBain
DBain's Avatar
Simple coil spring question.
I'm trying to install the lower control arm and coil spring on the front end of my 87 chevy 2wd. My manual says to use a compressor that works from the inside so I got one from a friend and I'm faced with a dilemna. Once the spring is installed, how do I get the compressor out? There's a hole in the bottom of the control arm, but the compressor wont fit through it. I don't want to try to install it because it just doesn't seem like it'll work.
So do I need an external compressor with long hooks to fit in between the arm and frame, or a smaller compressor to fit through the hole, or make the hole bigger in the control arm. Never done coil springs, just coil overs.
Thanks.
2000 Acura Integra LS
B18B1 1.8L 4cyl
2dr Coupe
1987 Chevy Scotsdale
350CI TBI 4sp Auto 2WD
2dr Std Cab Short Bed
DBain is offline   Reply With Quote
Old 10-09-2008, 10:06 AM   #2
DBain
DBain's Avatar
I know I know I'm a retard. About 30min after making this post I figured it out. Guess I should've put a little more thought into it before posting. Sorry!
B18B1 1.8L 4cyl
2dr Coupe
