Old 10-26-2008, 10:53 PM   #1
DBain
DBain's Avatar
Brake bleeding problem
Today I put my truck all back together after doing the front end. I disconnected the brake line on my drivers side front caliper to keep it from getting damaged. After reinstalling the line I went to bleed it and the bleeder is something I've never seen before. Generally there's a little nut at the bottom of the bleeder to put a wrench on but this one has either rotted away or the flat spot on it it for using vise-grips or pliers. It's too small for me the feel comfortable twisting away at it. So the question is has anyone seen a bleeder without a nut shape on it? Should I attempt to turn it? My concern is snapping it and needing a new caliper. Any help is appreciated.
Oh and it's an 87 chevy scottsdale with discs on the front.
2000 Acura Integra LS
B18B1 1.8L 4cyl
2dr Coupe
1987 Chevy Scotsdale
350CI TBI 4sp Auto 2WD
2dr Std Cab Short Bed
DBain is offline   Reply With Quote
Old 10-28-2008, 09:32 PM   #2
DBain
DBain's Avatar
Little update: I started by checking the other side and the bleeder looked exactly the same, which leans me away from it just being rotted, but you never know. So I sprayed it with PB twice, let it soak over night, and then when I got up the next day. Tried turning it with vice grips and it snapped right off.
I ended up taking the newer caliper off the spare frame, cleaning it up a bit and throwing that on. Problem solved. Have a good one.
B18B1 1.8L 4cyl
2dr Coupe
