Old 11-20-2008, 02:15 AM   #1
ONES
Exclamation Tranny And Rear Problems
When I Go 70 Mph And Up My Tranny Shakes Like Hell..........???what Might Cause This........?????
When Starting Off On First Going To Second Gear It Shakes And Wont Happen In Other Gears????????????
ONES is offline   Reply With Quote
Old 11-20-2008, 02:52 AM   #2
What kind of vehicle are we talking about. Some cars the hard 1-2 shift is considered normal (By the factory. Not backyard mechanics...). Also, are you positive it's your tranny shaking above 70? Sounds like a wheel balance issue to me.
Old 11-22-2008, 12:12 AM   #3
ONES
1991 Nissan 240sx.......I DONT THINK IS A WHEEL ALIGNMENT CUZ I PUT MY HAND ON THE SHIFTER AND ITS VERY SHAKY
Old 11-22-2008, 01:33 AM   #4
DBain
DBain's Avatar
No not the wheel alignment, the balance on the rim. I've only ever found that to happen between 45-60 but that's not to say it's not the problem. It you think your trans is shaking too much you've probrably got a bad mount. It's also possible but not likely that the driveshaft is either slightly warped or out of balance. I used to have a '90 240sx and my shifter would shake but it was from a busted motor mount
2000 Acura Integra LS
B18B1 1.8L 4cyl
2dr Coupe
1987 Chevy Scotsdale
350CI TBI 4sp Auto 2WD
2dr Std Cab Short Bed
DBain is offline   Reply With Quote
Old 11-23-2008, 06:31 AM   #5
ONES
Thats What I Was Thinking To A Motor Mount Or An Unbalanced Drive Shaft Cuz I Dropped My Tranny And Replaced The Clutch
Old 11-23-2008, 11:22 PM   #6
DBain
DBain's Avatar
What do you mean tranny dropped? as in it blew up?
B18B1 1.8L 4cyl
2dr Coupe
Old 11-24-2008, 09:39 PM   #7
ONES
i replaced the clutch..........and my dad didnt put the driveshaft back the same way i took it off
