Old 12-01-2008, 10:05 PM   #1
jayla
Question Acceleration problems...
This just happened today as I was driving my car a 1991 cadillac deville on my way home, the car just suddenly slowed down. I pressed on the gas to give it more power but it's not accelerating the way it normally does. I put it on park and it's still not accelerating. The car sounds different now like it's choking sounds rough. I never had any major problems, this is the first. Does anyone know what the problem is? THANX! Jayla
jayla is offline   Reply With Quote
Old 12-01-2008, 10:13 PM   #2
Originally Posted by jayla
This just happened today as I was driving my car a 1991 cadillac deville on my way home, the car just suddenly slowed down. I pressed on the gas to give it more power but it's not accelerating the way it normally does. I put it on park and it's still not accelerating. I never had any major problems, this is the first. Does anyone know what the problem is? THANX! Jayla
Any other symptoms or noises, steam/smoke, smells...otherwise it just sounds like you just ran out of fuel.
Old 12-01-2008, 10:19 PM   #3
Yea, it could be fuel, or a similar issue to what I had in my Pontiac which I suspect was the torque converter where the RPM would still rise and engine worked fine but there was a slipping type of effect going on between the engine and transmission.
Did the car start running rough or anything like that?
Old 12-01-2008, 10:19 PM   #4
jayla
acceleration problems...
It smells a little and it sounds different like it's choking. I filled up the tank yesterday.
Old 12-01-2008, 10:28 PM   #5
jayla
yes it runs rough and sounds rough like it's choking.
Old 12-01-2008, 11:38 PM   #6
Could be a misfiring issue then...in other words, spark plugs, wires, distributor/cap...or it could be something completely different.
What does it smell like?
Old 12-02-2008, 02:46 AM   #7
jayla
Smells like burnt rubber smell.
Old 12-07-2008, 10:23 PM   #8
jedmann1989
jedmann1989's Avatar
I agree. Check the fuel filter, spark plugs, wires, air filter. All the basic stuff.
My Cars:
2009 Ford Mustang GT TT
1993 Mazda Rx7 Twin Turbo LS7
1991 Mistubishi 3000gt VR4
Coming Soon:
Custom body C5 Vette
jedmann1989 is offline   Reply With Quote
Old 12-07-2008, 11:22 PM   #9
I'd change the fuel filter aswell. Maybe 15 bucks, and usually easy to replace. This alone will cause your studering issue, but not the smell. Also, if you change the FF, make sure you cycle the key on and off a few times to get fuel pressure back so you don't start it dry (Thats bad...).
