Old 12-19-2008, 12:26 AM   #1
maddog
maddog's Avatar
S-10 2.2L coolant leak @ cyl head rear
My daily driver is a 1995 Chevy S-10 LS, with the 2.2L 4-cyl & 5-speed, 182k miles. After driving it enough to reach operating temp, I can smell coolant from the exterior of the truck. I think I have a slow leak at the rear of the cylinder head. I have been topping off the coolant at the rate of 1/2 gallon every 300 miles. I've tried to visually locate it with the aid of an inspection mirror, but the clearance between the head and firewall prevents me from getting the right angle. I've tried to see it from underneath, but the trans is in the way. From up top, I can see the trail from the coolant follow the bellhousing down to the exhaust pipe. Ideas?
maddog is offline   Reply With Quote
Old 12-19-2008, 05:39 PM   #2
Blown Head gasket. Take it somewhere to get it fixed unless you know how to work on engines. there's a lot of important things you have to remember in order to do it yourself.
Old 12-22-2008, 06:25 AM   #3
A 95 S-10 with almost 200K on it is probably not worth bringing to a shop to have a headgasket replaced. You can buy gasket sealant at about any autoparts store for a few bucks. Not a permanent fix, but I did it once on my car and its been leak free for a few thousand miles.
Old 12-22-2008, 03:45 PM   #4
maddog
maddog's Avatar
Thanks to who have replied. I was leaning toward the freeze plug in the head (I've had them go bad in the block on other vehicles before). The head gasket would get replaced regardless. I've done a temporary fix with some stop-leak, it seems to have slowed the flow. Doing the work myself is no problem, I've torn 'em down and put 'em back together more than once. Just looking for a game-plan before tearing this one down.
Old 12-23-2008, 02:31 PM   #5
Have fun. 2.2L S-10s are probably the only trucks I wouldn't lift the cab off the frame to do a head gasket. They're open enough to pretty much get at everything.
Old 12-23-2008, 05:45 PM   #6
maddog
maddog's Avatar
It will be a couple of weeks before I can schedule some down-time for the S-10. I'll let you know what I find.
Old 12-24-2008, 03:11 AM   #7
Sounds good!
Old 12-27-2008, 03:17 AM   #8
cszygenda
using stop leak
If you have already used stop leak.... do yourself a favr and flush your coolant system asap.....stop leak is known to plug heater cores especially in gm vehicles.
cszygenda is offline   Reply With Quote
Old 12-28-2008, 09:05 PM   #9
DBain
DBain's Avatar
The 2.2 do give you a lot of room... once you take off all the plastic intake garbage. I hate those motors, head gaskets are very common.
As for cszygenda's comment. Very true I saw it happen to a sable. Really nice car, my buddy got an incredible deal on it, ran nice, rode nice. But no heat. Only drops of coolant and little peices of hardened stop leak came through the core. Long story short, down the road it went.
2000 Acura Integra LS
B18B1 1.8L 4cyl
2dr Coupe
1987 Chevy Scotsdale
350CI TBI 4sp Auto 2WD
2dr Std Cab Short Bed
DBain is offline   Reply With Quote
Old 04-26-2009, 02:50 PM   #10
Moxymech1
Maddog, what did you find out?
I am having the same problem, but i noticed that when i am not using the heat or def it doesn't leak a much. I am wondering if it is the heater hoses at the engine?
Was it the head gasket?
moxy
Moxymech1 is offline   Reply With Quote
Old 05-19-2009, 11:49 PM   #11
Moxymech1
TTT
Still having problems i have searched high and low for the source and i can't seam to find it, only leaks when heat or defrost is on
Old 05-26-2009, 10:16 PM   #12
maddog
maddog's Avatar
Moxymech,
The problem with my S-10 is a bad head gasket. I haven't replaced it as of yet (I drive it daily), I stopped the flow with a second round of stop-leak. As for your leak, I am puzzled by the fact that it only leaks when the heater or defrost is operated. What year is your truck? On my '95,coolant always flows through the heater core when the engine is running. The mode of the Heat/Air Controller should not determine when the leak occurs.
Maddog
Old 05-27-2009, 11:35 PM   #13
Moxymech1
Moxymech,
Maddog
I also drive mine daily and keep the fuilds up, keep an eye on the temp gauge, and avoid long trips. Mine is a 4cyl 1995 S10 with manual transmission, I have around 167,000 miles.
I am not 100% on mine leaking only when the heater is on, i noticed it was leaking more this winter, now that the weather is more on the mild side it seems to be leaking less.
I have not tried stop leak or any additives to avoid plugging up the heater core.
I was thinking about having a leak check done on it, but have not done so yet.
The neighborhood garage did a 15psi test on the cooling system with no loss in presure, not sure if it could be different when HOT?
Moxy
Old 06-01-2009, 12:54 PM   #14
maddog
maddog's Avatar
Moxy
I'm willing to bet that you are smelling this leak rather than seeing it. If so, the pressure test will not show pressure loss, because the leak is really small. I have had the pressure test done a couple of times on mine. The first time they said there were no leakage, the second time I was told a couple of hose clamps were loose (I had just replaced all of the hoses). End result: Still Leaking! So, my cheapest last resort was to use stop-leak. When the leak finally stopped, I was able to find the source by following the dried trail of stop-leak: Head Gasket @ Rear of Cylinder Head. Have the leak test done to pin-point your leak.
Maddog
Old 06-02-2009, 05:37 PM   #15
Moxymech1
Thanks Maddog,
I am not in too much of hurry although it would be nice to get this done while it is still summer.
How much of a pain is it to replace the head gasket on this engine?
If the body and frame were not in great shape i wouldn't even think of sinking money into this vehicle. It is the last of the small block trucks is it not!
Moxy
