Old 01-11-2005, 07:51 PM   #31
Godlaus
UnFedFat in Disguise
Godlaus's Avatar
Originally Posted by ChrisV
You were wrong then, too. A production car is one that is in series production by a factory. Whether that's 27, 100, 100,000 doesn't matter.
The ONLY time it matters is in FIA racing, where "production" figures have to be satisfied for homologation rules. SOme classes put that at 10,000, some put it at 100. But the fact remains that there are no actual numbers other than series production by a factory to count as a "production" car.
So the 100 McLaren F1s count, and the Saleen S7 counts.
So why was the lanbourghini murcielgo considered the fastest production car when the enzo was in production?
I dunno. Somehow I figured that production cars were ones that were out there for a while, for the general public, like the civic and camry, etc etc.
I am everything you want to be
Old 01-11-2005, 08:11 PM   #32
becaeu the Enzo's tested top speed was not as high as teh Murci's/ the Enzo was not designed for top speed, and had actually been toned down in that regard from the faster F40 and F50.
You figured wrong. the term production means series produced in any quantity that is not a prototype. As the example in the other thread indicated, should teh S200 not be considered a "prodution car" because it equals a mere 10% or less of Civic production figures?
The FIA tends to make the lowest number for series production stand at 50-100, depending on class (and some racing classes require more, thus homologation specials like the Escort Cosworth). DOT and EPA regs state less than 50 produced make you a smal lmanufacturer not needing to meet certain regulations. But that figure is stil considered production, just not MASS production.
Series producing multiple examples using tooling created to duplicate the example, and using interchangeable parts, make a car a production car, as it's being produced in numbers greater than 1 or two. Even the Vector W8 was considered a "production car" though there were only 25 made.
Old 01-14-2005, 11:24 PM   #33
Read what I said on this page;
http://www.car-forums.com/talk/showthread.php?t=8149
it's my second post down.
Not the New S7, the one that came out 2nd Quarter 2004.
Old 01-17-2005, 07:10 AM   #34
abless
CF Anti-Mullet
abless's Avatar
Originally Posted by SCARECRW
WAT I MEANT WAS STOCK MUSCLE THAT SALEEN S7 ISN'T A MUSCLE
BUT CHEACK THE SPEC ON FORD TYPHOON
The all-new F6 270. A 4-litre turbo-charged, intercooled, 24-valve double overhead cam six. The highest torque output of any production six ever built in Australia and one of the most powerful in the world. Through partnership with Prodrive and their mastery of turbo technology across F1 and World Rally, the development of our high performance turbo-charged FPV will change performance cars forever. We created a new engine with dramatically improved cooling and induction. The 50% larger air-to-air intercooler and dual air intake system significantly reduces intake pressure into the turbo's compressor - allowing it to work more efficiently...and effectively.
The result. A fully engineered performance-driven power generator. Armed with double overhead camshafts and 4-valve aluminum cylinder heads, the F6 270 produces its maximum power of 270kW at 5250 rpm. However, the real story is torque. All 550Nm on tap from just 2000 rpm and remaining constant all the way through to 4250 rpm.
At time of launch, the highest torque output of any production engine ever built in Australia. Even more staggering is the engine's ability to produce 80% of its maximum torque at 1500 rpm and over 98% at 1750 rpm. Total Performance meets the turbo. HEAVY
This is so obviously cutting and pasting. This can be easily determined by reading his other posts, which are done without regaurd to grammar or content. Stop plagarizing other people and stop being an arrogant (village) idiot.
abless is offline   Reply With Quote
