Old 01-15-2005, 06:06 AM   #1
CarEXPERT
Turbo Questions
hi.. why do people say when you use high boost your engine detonates. Is it better to have low compression or high in your engine? Honda's have weak engines so turbos are not good for them. Do you have to get aftermarket internals to run high boost in hondas?
Old 01-15-2005, 06:12 AM   #2
1. Define high boost.
2. For what?
3. Really, that's new.
4. Refer to #1.
Old 01-15-2005, 06:16 AM   #3
CarEXPERT
2. For what?
4. Refer to #1.
Hi Mr. Sir. Vwhobo... I read this artical that says you cant run more than 5-8 psi of boost on honda/acura engines because of the compression ratio. 5-8 psi wont get you much power so if you wanted to make more power without ****ing up your engine what do you need to do.
Old 01-15-2005, 06:25 AM   #4
If this article is so filled with pertinent information, why doesn't it have the answer? Okay, maybe you don't know that, but... It would be much easier to address the article if we knew exactly what it said.
Old 01-15-2005, 06:28 AM   #5
Running any sort of boost on your engine is more damaging to your engine then if you didn't run boost at all. This doesn't mean that by having forced induction you are going to blow your engine, it just means that you are putting it under more stress, and eventually might break something inside it.
As for the compression, that all depends, if you are trying to have a high power engine, the higher the compression the better. But if you are running a turbo or SC then you should run a lower compression to reduce the risk of detonation.
I don't know where you came up with the idea that honda engines are weak. Honda makes some of the most durable DOHC 4 cylinders out there, and they are coming along with there V6 technology as well, take the accoard as an example. Why do you think people can put a turbo and nitrous systems on their hondas and then still use their cars as daily drivers for 150,000 miles? While some of the less performance oriented engines will take to abuse like that far less complacently, Hondas more race oriented engines (such as the B or K series) will do this with much more ease.
Putting aftermarket internals are usually a great Idea when running a forced induction setup on any car, not just hondas.
Old 01-15-2005, 07:05 AM   #6
b_DuB13
b_DuB13's Avatar
CarEXPERT: Do not believe everything you hear.
The reason some Honda engines don't respond to turbo very well is because of their VTEC (Variable Valve Timing and Electronic Control...I think)
I have heard from many credible sources the the Integra GSR B18C is very non turbo compatible...
well anywho, I just got off from a 6 hour shift at the world's crappiest mexican resturaunt...so maybe I shouldn't be posting right now.
92 Isuzu Rodeo, RWD auto, 121,000ish miles.
(2) Kicker Comp 12inch subs in a huge, custom box. (1) JBL 600w (300w x 2) amp.
(2) Pioneer 6.5inch speakers in the rear, (2) 4.5ish speakers in the front.
PROJECT CAR:
1982 datsun 280zx
121,000 ish miles.
non turbo (for now)
3 speed auto (for now)
silver, black detail.
(pics soon)
b_DuB13 is offline   Reply With Quote
Old 01-15-2005, 07:08 AM   #7
The problems with Vtec can be simply solved with some advanced tuning, which is a step that should be taken anytime a car is equipped with a turbo. I was just saying that honda engines are very strong, durable engines and can take the abuse of a turbo.
EDIT:
By the way, what mexican restraunt do you work at?
Old 01-15-2005, 07:21 AM   #8
b_DuB13
b_DuB13's Avatar
EDIT:
HOLY SHIT THAT WAS A FAST REPLY
oh, and I wasn't saying anything about your previous post. I'm to tired to put that much focus into anything right now. I'm sure whatever you said about vtec and stuffs is correct...
Maybe you were speaking of some type of engine management systems? aftermarket CPU's? "VTEC controllers"? (my friend has a "vtec controller" on his jdm d16a civic coupe)
haha. he set his vtec as low as possible, at idle, he says.
he's going to blow that engine, I know it. Oh well, he's already on his third. (it's funny how honda owners talk about engines as though they are trading cards.)
Oh, and I work at a piece of shit local chain called ponchos and charleys
food isn't bad, but co workers are spoiled and stupid.
PROJECT CAR:
1982 datsun 280zx
121,000 ish miles.
non turbo (for now)
(pics soon)
Old 01-15-2005, 07:27 AM   #9
yea, my friend in an SVT focus raced a CRX with a B16a2 in it and beat him,but only beacuase the guys vtec didn't kick in quick enough after his shifts. The CRX would pull on my friend while in Vtec, but as soon as he shifted he dropped back farther and farther. He promised to get a Vtech controller and race again but we never saw the guy again.
Old 01-15-2005, 08:15 AM   #10
b_DuB13
b_DuB13's Avatar
holy crap, that SHOULD be a really fast car.
The way that VTEC is set up in my friends 5th gen 97 prelude is that, if he's flooring it, (the VTEC opens up at 5100, redline at 7200, i think) when he shifts to second, his revs dont drop and all of his valves stay open
this probably doesn't make any sense.
I'll try and edit this tomorrow.
It may be that the crx's aftermarket engine didn't have the VTEC configured properly...
either way, I hate focus'..heh
PROJECT CAR:
1982 datsun 280zx
121,000 ish miles.
non turbo (for now)
(pics soon)
Old 01-15-2005, 10:39 PM   #11
CarEXPERT
Civic rods are more prone to snap than others and in an integra, for example, the piston ring lands will give before the rods go. Trust me im a car EXPERT.
Old 01-15-2005, 10:44 PM   #12
CarEXPERT
You can control when vtec kicks in with the vtec controller? I never heard of that but the vtec should be adjusted in the factory so it give you max power.
Why is it harder to turbo a car that is vtec than a non vtec? The turbo shouldnt even disrupted the vtec system because the turbo is outside the engine. can anyone help please
