Old 01-18-2005, 03:40 AM   #1
CarEXPERT
How to do a Quick Launch with a manual Car
In a fwd car, how would you do a quick launch with a stick.
In a rwd, how would you do a quick launch with a stick.
In a awd, howwould you do a quick launch with a stick.
I dont want to do burnouts! just quick.
Old 01-18-2005, 03:53 AM   #2
2002_EVO_VII
2002_EVO_VII's Avatar
Practice...
Google it coz none of us can be bothered to write it out...
Its not that i drive too fast.. Its that everyone else drives too slow...
2002_EVO_VII is offline   Reply With Quote
Old 01-18-2005, 04:03 AM   #3
CarEXPERT
how do you google something like that?
Old 01-18-2005, 04:10 AM   #4
2002_EVO_VII
http://www.google.co.uk/search?num=1...hniq ue&meta=
Old 01-18-2005, 04:30 AM   #5
CarEXPERT
Originally Posted by 2002_EVO_VII
Nice man! THANKS! sorry for being an asshole
Old 01-18-2005, 04:33 AM   #6
2002_EVO_VII
Thats ok so long as you learn from your mistakes...
Old 01-18-2005, 05:33 AM   #7
Well in a gtr just dail up the revs and drop the clutch.
Old 01-18-2005, 05:34 AM   #8
CarEXPERT
I dont know what drop the clutch means!! help
Old 01-18-2005, 05:48 AM   #9
Old 01-18-2005, 06:13 AM   #10
Really? You don't know what a clutch is?
Please just look it up on howstuffworks.com
Thats a lot of typing.
Old 01-18-2005, 06:15 AM   #11
~SK~
~SK~'s Avatar
ROTFLMFAO
~Here But Not Really~
~SK~ is offline   Reply With Quote
Old 01-18-2005, 04:38 PM   #12
CarEXPERT
I know how a clutch works but i dont know what your doing when you drop the clutch or when you slip the clutch. How do you slip a clutch?
Old 01-18-2005, 05:17 PM   #13
Godlaus
UnFedFat in Disguise
Godlaus's Avatar
*sigh* Why do you even use the username 'CAREXPERT'? You don't even know what a clutch is. Tell me this, in a manual car, there are three pedals (surely you must have noticed that), there's clutch, brake, gas in order of left to right. The clutch is a metal plate from the engine that rubs against another metal plate to move the driveshaft, hence to move the wheels. You put in the clutch (moves plates apart) to shift gears or go to neutral. You drop the clutch by removing your foot from the clutch pedal extremely quick. A drop clutch start is where you rev the engine, then drop the clutch to get the wheels movng quickly. (You need to do drop clutch starts on non-torque engines). It's the difficulty of dropping it at the right RPMs to not spin the tires and get the perfect traction, while not destroying your driveshaft and clutch and transmission.
Take driver's ed before posting any more questions, that's an order.
I am everything you want to be
Old 01-18-2005, 06:29 PM   #14
2002_EVO_VII
Originally Posted by Godlaus
*sigh* Why do you even use the username 'CAREXPERT'? You don't even know what a clutch is. Tell me this, in a manual car, there are three pedals (surely you must have noticed that), there's clutch, brake, gas in order of left to right. The clutch is a metal plate from the engine that rubs against another metal plate to move the driveshaft, (Hmmm.. Did someone forget to put the friction plate in last time the gearbox was removed?) hence to move the wheels. You put in (surely depress is a better word??) the clutch (moves plates apart) to shift gears or go to neutral. You drop the clutch by removing your foot from the clutch pedal extremely quick. A drop clutch start is where you rev the engine, then drop the clutch to get the wheels movng quickly. (should there not be something about finding the biting point first?) (You need to do drop clutch starts on non-torque engines ). (hmm...non-torque engines? You'll have to do ALOT more than just drop the clutch if you engine produces NO torque.. ) It's the difficulty of dropping it at the right RPMs to not spin the tires and get the perfect traction, while not destroying your driveshaft and clutch and transmission.
Good job your not called carEXPERT either...
Seems all i do is pick up on peoples faults here, and thats not really a valid contribution IMHO...
Note: I would like to apply for the job of Hobo Jr if there is an opening..
Many thanks in advance.
Old 01-18-2005, 08:33 PM   #15
Godlaus
Godlaus's Avatar
I don't know all the exact physics of clutches, but my explanation was a basic overview. Any more information would have made carexpert's head explode.
Friction plate. Liek I said, mine was a basic overview, and that's basically what a clutch is, two plates rubbing against each other.
Depress is a better word, thanks for the tip.
Biting pont. Considered explaining it, but like I said, any more info would make carexpert run screaming into the night clutching his head. What is the traction point on a civic anyway? 5000 RPMs?
By non-torque engines, I meant low torque engines, like the civic. A auto civic isn't very fast on the launch as compared to a stick civic.
Never said I was.
It's important to pick up on people's mistakes, to recognize and correct them in your own head, unless people start to take the false info as true, then you publicly state the fallacies.
Like I said, just an overview.
